TwinTurbo.NET: Nissan 300ZX forum - What color is the smoke? (n/m)
550HPTT
on August 09, 2008 at 8:31 PM
Re: Sounds like you have leaky turbo's
posted by zya300
on August 09, 2008 at 08:27 PM
PROBLEM!.... Turbos? Timing? Air to Fuel Ratio?
zya300
13:14:44 08/09/08
550HPTT
13:47:13 08/09/08
zya300
20:27:53 08/09/08
What color is the smoke? (n/m) -
550HPTT
20:31:14 08/09/08
Re: What color is the smoke?
zya300
20:33:16 08/09/08
White smoke is from water
550HPTT
21:28:52 08/09/08
Re: White smoke is from water
zya300
21:42:23 08/09/08
HeadGasket leaking, you can pull the plugs as I mentioned
550HPTT
21:59:59 08/09/08
Re: HeadGasket leaking, you can pull the plugs as I mentioned
zya300
22:12:37 08/09/08
Re: Re: HeadGasket leaking, you can pull the plugs as I ment
zya300
11:24:59 08/10/08
